주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dyson AM07은 2014년에 출시된 날개 없는 타워 팬입니다. AM07은 "에어 멀티플라이어(Air Multiplier)" 기술을 사용하여 눈에 보이는 날개 없이도 부드러운 공기 흐름을 만들어냅니다.
fan not oscillating back and forth
What's wrong and how do I fix it?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개
I have the problem too, it is not oscillating.
의 공유
댓글 달기
답변 2개
선택된 해법
mkoch, If it is new, did you remove the tape, from the lower base body split section, if not remove before turning on any more or damage to internal gear could occur. Recheck that the fan is still assembled correctly and locked in correct position. Install new batteries in remote and try. If all looks good and still under warranty return for repair/replacement/refund as there may internal damage to oscillating gear. See below links, your manual and Dyson support site.
Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.manualslib.com/manual/888752...
https://www.dyson.com/support/am02/am02-...
이 답변이 도움이 되었나요?
점수 7
댓글 2개:
So simple, duh, I forgot the tape. But it doesn’t show that in the setup instructions.
의 공유
I need help in opening the remote. I've had three people look @ this remote. Pls help!!!!!!!!!!!!
의 공유
댓글 달기
It would be more helpful if the tape that has to be removed was an obviously different colour rather than white the same as the oscilating plinth - ie ... make it idiot proof - it took me a while to work it out as well lol
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
mkoch 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 18
지난 30일: 92
전체 시간: 51,107
