주요 콘텐츠로 건너뛰기
A cordless electric razor manufactured by Philips in 2006.
3 질문 전체 보기
What if the batteries are worn-out?
What if the batteries are worn-out? It might be a simple replacement process; I have this problem also, but I don't know how to remove the back cover TO replace the batteries...
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개
How do you replace the battery in the Philips Norelco 7110X
댓글 달기
답변 1개
선택된 해법
@landanm , @scottdeutsch , Scott D. Deutsch, Some devices do not power on when charging, I am not sure if that is the case for this shaver or not, to answer @landanm inquiry. If you have a Philips Norelco 5801XL find below a guide to battery replacement. This will also give you a chance to look at other components/wires that could be loose/damaged/burnt. I suggest you first try another compatible charger or have charger tested and also if able clean the charge port of any dust/lint carefully with tooth pick or blow out with canned compressed air. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Philips Norelco 5801XL Battery Replacement
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Scott D. Deutsch 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 3
전체 시간: 786
