์ฃผ์š” ์ฝ˜ํ…์ธ ๋กœ ๊ฑด๋„ˆ๋›ฐ๊ธฐ
๋‚ด ์ž‘์—…๋Œ€
๊ธฐ๊ธฐ์— ๋Œ€ํ•œ ์•ˆ๋‚ด์„œ, ๋ถ€ํ’ˆ ๋ฐ ๋‹ต๋ณ€์— ์‹ ์†ํžˆ ์ ‘๊ทผํ•  ์ˆ˜ ์žˆ์Šต๋‹ˆ๋‹ค
The Sony GTK-XB5 is a high powered home audio system with Bluetooth that was released in 2016. This audio system is available in black, red, and blue.
16 ์งˆ๋ฌธ ์ „์ฒด ๋ณด๊ธฐ
Is it possible to add a battery
is it possible to add a battery?
์ด ์งˆ๋ฌธ์— ๋‹ตํ•˜๊ธฐ ์ €๋„ ๊ฐ™์€ ๋ฌธ์ œ๊ฐ€ ์žˆ์Šต๋‹ˆ๋‹ค
์ข‹์€ ์งˆ๋ฌธ์ž…๋‹ˆ๊นŒ?
์ ์ˆ˜ 4
๋Œ“๊ธ€ 1๊ฐœ
There is now the XB60 and XB90 with in built battery
๋Œ“๊ธ€ ๋‹ฌ๊ธฐ
๋‹ต๋ณ€ 4๊ฐœ
๊ฐ€์žฅ ์œ ์šฉํ•œ ๋‹ต๋ณ€
becki2000seb besides all the sarcasm here is a short answer. No. The power requirements for your Sony GTK-XB5 are to large for a battery.
์ด ๋‹ต๋ณ€์ด ๋„์›€์ด ๋˜์—ˆ๋‚˜์š”?
์ ์ˆ˜ 3
๋Œ“๊ธ€ 1๊ฐœ:
Apologies if it was taken as a sarcastic answer. I am used to carrying around external batteries. They even make them for laptops. A first generation HyperJuice was a literal brick.
https://www.hypershop.com/products/hyper...
๋Œ“๊ธ€ ๋‹ฌ๊ธฐ
The power consumption of your battery is 30w.
You need something of massive capacity, something like this:
https://www.amazon.com/Portable-Generato...
์ ์ˆ˜ 2
๋Œ“๊ธ€ 3๊ฐœ:
I don't know why this is funny, but it is.
True. I wish I could put an inbuilt battery some how
some bike battery could work?
๋Œ“๊ธ€ ๋‹ฌ๊ธฐ
I like reviving olde threads, especially ones with no decent answer! I found lithium scooter battery packs with built in BMS charging circuits integrated on Ebay. Wire in a charger for when the thingโ€™s plugged in and youโ€™re solid, long as you can also convert the electricity inside to amp the board, also :)
์ ์ˆ˜ 1
๋Œ“๊ธ€ ๋‹ฌ๊ธฐ
I used a 36 volt 2.6Ah battery for mine after the power supply in it die and it works great.
์ ์ˆ˜ 0
๋Œ“๊ธ€ 1๊ฐœ:
I use a 36 volt Ryobi power tool battery because the power supply in it died.
๋Œ“๊ธ€ ๋‹ฌ๊ธฐ
๋‹ต๋ณ€์„ ์ถ”๊ฐ€ํ•˜์„ธ์š”
becki2000seb ์˜์›ํžˆ ๊ฐ์‚ฌํ•  ๊ฒƒ์ž…๋‹ˆ๋‹ค.
์กฐํšŒ ํ†ต๊ณ„:
์ง€๋‚œ 24์‹œ๊ฐ„: 5
์ง€๋‚œ 7์ผ: 11
์ง€๋‚œ 30์ผ: 22
์ „์ฒด ์‹œ๊ฐ„: 9,075
