Flickering when low light
How to solve plssss my j7 flickers when on low light how to fix help me pls should i replace the lcd or their is other things to replaced or it just needs something to be solved ?
좋은 질문입니까?
좋은 질문입니까?
@kobexkyrie seems to be a very common issues with this model. It is the backlight that is flickering at higher/lower power demands. Could be filter or power IC as well as the Amoled. Take a look at Flickering screen on low back light and see if some off that will work for you.
이 답변이 도움이 되었나요?
Sir what do you mean of off ?I just updated the model than it started flickering
@kobexkyrie of off ? I was stating that this seems to be a common issue with this model phone. Check the answers on the link in my answer to you. Click on the light blue writing :-)
Thanks for the help it helps me a lot to save
Sir unluckily it didnt work even the screen filter doesnt work also what should i do
지난 24시간: 0
지난 7일: 5
지난 30일: 24
전체 시간: 17,573
댓글 1개
my samsung J7 camera light cannot go off. steady ON
Philip Onyia 의 공유
