주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Overheating Television With Smoke
I heard a small pop in the back of the tv then white smoke and a burning smell came from the tv.
Update (07/30/2017)
이미지
이미지
이미지
이미지
Images, Model, and Board where smoke is coming from.
Update (07/30/2017)
이미지
이미지
Plugged it in with the back off, the smoke is coming from burning on the board about 6 inches above the power supply.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 7개
Your tv gets a short-circuit on the motherboard.
의
Smoke was coming out my TV, it still works perfectly. The only problem is that the sound starts to crack after a short time of watching something
의
I have a 39 in Visio TV
의
I have the same problem of smoke and small water that cames out to my tv the name is Muller&haupt tv the time I so the smoke I did switch it off sametiy what could be the problem
의
The same thing happened to my sinotech while is off but the generator was running so I just see a smoke at the back of the TV and the decoder as well
의
댓글 2개 더보기
댓글 달기
답변 2개
선택된 해법
@knarf1 well sounds like one or a couple of components went up in smoke. Unplug the set and do not use it until you identified the issue. Let us know exactly what model your TV is. Remove the back of your set and take a close look at the boards to see if you can identify which component(s) have gone up in smoke. Post some good images with your question so we can see what you see. Use this guide for that.
Update (07/30/2017)
Looks like multiple failure here.
이미지
Burned capacitor and possibly bad IC. You can either replace the complete power board or try to find a schematic to replace the individual parts. We still do not know what model your TV is. Repalcement power supply is available at places like this and many more.
Genuine Samsung component for 51 CLASS Plasma TV models, addressing power-related issues. 이미지
제품
BN44-00599A - Samsung DC VSS-Power Supply Board
$239.99
이 답변이 도움이 되었나요?
점수 2
댓글 6개:
Today o experienced the same issue with armaco tv...i just bought it yesterday and now it has produce a pop sound with white smoke... .but after reconnecting its still working normaly
의
Ours is an insignia smart LED tv. It just arrived now and the back began to smoke when we plugged it in to the wall socket
의
I experienced same issue this morning with via low current issue. I run to my living smoke popped up smoke with smell of burn but I haven’t reconnected it what should I do pls
의
@josephfran68098
Disconnect the power to the TV, remove the back cover from the TV and then check the boards for any sign of damage i.e. burnt out components.
Post some images of what you find back here in a new question on ifixit. Don't forget to add the make and model number information if you do.
의
Mine just did the exact same thing ! I heard a little like pop/hissing sound and I look up to see smoke protruding from my ONN(Walmart) tv!!! I’ve had it for over 5 years now and only paid about $230 for it- so technically I should just replace it…. Right!?🫣
의
댓글 1개 더보기
댓글 달기
For everyone's reference, a POP with WHITE smoke is most always a capacitor. It might be a small one or an electrolytic
The pictured problem is probably a bad transistor/SCR/MOSFET and it looks like a capacitor associated with it. However, the black burn marks could be coming out of that thru hole where the heat sink is attached and be a result of a bad solder joint.
No telling how many components were damaged.
The failure might have been created by another problem elsewhere.
If you have a DVM and enough expertise to check components on the board or remove them and check them and find a definite bad part, it may be fixable. Remove the bad parts. Clean up all the black stuff - it creates resistance shorts.
Replace parts and try again. Or just replace the board. If you can find service info, it is best to verify there is no problem on another board that lead to this.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Frank 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 27
지난 30일: 170
전체 시간: 44,916
