주요 콘텐츠로 건너뛰기
A collection of guides and support to help with washer repair.
3473 질문 전체 보기
Why did my washing machine just keep running water for two hours?
My Kenmore 400 washer just over filled and ran water for two hours. Obviously there is a flood in the basement.
Last week I changed the lid switch which should have nothing to do with the water level sensor or however it works.
My question is why did it happen?
Did something come unplugged or become misplaced or miscalibrated? The water never stopped filling in and I do not know why.
Thanks
Frank
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 1개
It's only my cold water
댓글 달기
답변 2개
선택된 답변
Here is a really good site that explains things like your overflowing washer very well http://www.davesrepair.com/DIYhelp/DIYws... If the washer is off and the machine keeps filling with water, than you must have a water fill valve that is stuck, usually the cold water one. If the machine is on and is overfilling I would think that you have a water level switch that is bad or the hose that attaches to the switch and the bubble on the side of the tub has come loose. I do not think that it has anything to do with your lid switch. Hope this helps and good luck.
해당 답변은 도움이 되었습니까?
점수 3
댓글 3개:
Yeah, that was more or less what the reasons were.
+ nice resource
What does the water fill valve look like?
댓글 달기
@Kevin Case
What is the make and model number of the washer?
If only the cold water, then there may be a problem with the cold water inlet solenoid valve, not closing properly when the power to it is disconnected.
The valves cannot be repaired they have to be replaced.
Knowing the make and model will help to find the correct part, because with some washers the valves come as a set i.e. both hot and cold inlet valves and with others they can be individually replaced.
Also check the mesh filters located in the hose fitting at the washer end of the hoses that supply the water to the machine. If it is damaged then any grit in the water supply can get in and this may lodge in the valve seat stopping it from fully closing. Replacing the filter if damaged won’t fix the valve but may prevent it from happening again to the next one
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
040304 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 6
30일 전: 25
전체 시간: 24,531
