주요 콘텐츠로 건너뛰기
A multi-function laptop in the, now discontinued, L640 series by Toshiba.
6 질문 전체 보기
My network led not blinking
I have serious problem with my laptop
First the network icon is red X and said Not Connected
The network/ Lan led is not blinking,.
Fn F8 which use for turn on/off lan is missing
Is my lan card broken or what? I try for download driver but not solve the problem, now I'm really frustating
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 5개
What OS version are you using?
@richie01 has it worked for you before?
Hi,
Have you checked in Device Manager to see the state of the LAN adapter? What does it show, working OK, disabled, problem etc?
If disabled have you tried to enable it in Device Manager? (right click on entry and select enable).
If you cannot enable it in Device manager,check in BIOS and see if there is an entry in there to disable/enable the LAN.
I check in device manager and it show nothing, try install driver but show message the adapter is not found, i using win 7
And its enable on bios btw
댓글 달기
답변 1개
선택된 해법
Hi @richie01 ,
Here is a link to the ifixit dis-assembly guide for your laptop.
Since I'm assuming that you are referring to the WLAN (as you mention trying Fn + F8), at Step.6 in the guide it shows how to remove the wireless card. Check that the wireless card has been inserted properly. If it seems to be inserted firmly then perhaps the WiFi card is faulty and needs to be replaced.
If you search online for a Toshiba Satellite L645D-S4056 WiFi /Wireless adapter card you will find suppliers of the adapter. They don't appear to be that expensive.
이 답변이 도움이 되었나요?
점수 3
댓글 2개:
i don't know man, i can connect to internet with USB theatring from my phone, but for wifi hotspot its only Show X RED icon, i try to install driver but nothing happen
Hi @richie01 ,
As I said above in my answer you need to check the WiFi adapter card is seated properly and possibly replace it to prove where the problem lies. Your laptop is saying that it is not there.
USB tethering uses different hardware.
댓글 달기
답변을 추가하세요
Richie 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 3
전체 시간: 667
