주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Kenwood Chef A701A는 Kenwood에서 출시한 스탠드형 푸드 믹서입니다.
How do I replace latch pin?
How do I replace the latch pin?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
@noreenmcgrath check the diagram and see if you are referring to the catch pin (25) or the hinge pin (49).
From the SM
이미지
Catch Pin and Quadrant Assembly
  • Lift head of mixer
  • Remove circlip (27) from out end of Catch Pin (25), slide catch pin out fro Pedestal (37), the spring (26) is now free.
  • When refitting circlip, Tool KT 10168 is available, which will assist in retaining clip whilst being refitted to catch pin.
  • To remove Quadrant assembly, first carry out previous instruction 1 and 2.
  • Remove for screws (31) securing Body cover (30), allow body cover to drop.
  • Access is now available to two screws (29) securing Quadrant assembly to Body assembly.
Post some images of the pins etc. with your question. Use this guide 기존 질문에 이미지 추가하기 for that. That way we can see what you see.
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
Hi @noreenmcgrath ,
The part that I referred to in my answer to your earlier question Mixer opening when mixing is #25 . It also says that full instructions will be given with the part.
Hopefully this adds to @oldturkey03 excellent answer
의 공유
댓글 달기
Connect top slide facing downwards towards the machine not sideways. Slide latch assy through with the handle going through the slide. Place plastic attachment through hole on the left with spring and connect spring on the wall that the plastic piece is in. Turn until you have tension where the round area is towards the the insert hole. Your handle should be facing down. When you close it should catch. Any more questions shoot me an email at lapsuslingue@yahoo.com
이 답변이 도움이 되었나요?
점수 -1
댓글 달기
답변을 추가하세요
Noreen 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 12
지난 30일: 65
전체 시간: 5,192
