주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2015년 9월 25일 출시. Model A1688/A1633. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
Motherboard components change help?
Im looking at changing the following chips between two matching iPhone 6s.CPU chip, Qualcomm baseband ic, nand memory chip, my question is after getting them both finished will i need programming tools? For each chip? When i first researched this it looks like you can just switch them and turn them on. Now I'm being told differently. Also I was just told I'm missing a piece. Yes this is for refurb of phones with iCloud activation lock. Clean imei not stolen
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 2개
Based on what I see in the video he has the special equipment to see the chip turn on? And apart from that they were pretty regular tools based on what I've seen. Why are people surpressing the info
No one is suppressing any info. There are tons of videos showing how to micro-solder NAND's, Baseband and even CPU's. There are folks in Asia doing this daily using low-end tools and working on denim-covered "workbenches".
However, if you think this is straightforward...then go ahead and try it. Just make sure to report back to tell us how it went :>). You might want to read through this Q&A (Replacing fpc connector because touch screen is not working), especially the comments where this very issue is brought up and @arbaman bravely admitted that his first attempt on a much easier repair did not go well at all (with pictures to boot!).
댓글 달기
답변 2개
선택된 해법
That's an awful lot of work to "remove" the iCloud lock. If you have a perfectly good logic board that is not locked, why not just put the whole logic board in the good housing? If it's just a memory capacity issue, you can upgrade just the NAND.
Don't be fooled by the apparent ease with which the tech does the swap in the linked video...these guys are insanely skilled and they have done this hundreds of times to be that good. If you have never done anything similar, you will not succeed on your first attempt.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
yes as @refectio says if the board you suspect has no icloud is ok why not just use it
댓글 달기
가장 유용한 답변
See this video.
Hope it helps.
https://www.youtube.com/watch?v=G-tbLa7e...
이 답변이 도움이 되었나요?
점수 1
댓글 4개:
Well how do you know if one is clean? Anytime you buy one it seems they come up iCloud locked anyway once they are in working order. I'm mainly trying to find the easiest way to buy low, and refurb. If anyone is ok with going through this process with me or the easiest process available I'll be a diligent student. There are people that I can pay locally to solder the parts but it seems the are saying that they need all this extra equipment for the programming of these chips
It doesn't matter. It doesn't need to be clean. As long as those components are changed, reload the iOS, then it is no longer locked from my understanding.
@avanteguarde you need to read up on this a bit more ;>). The activation lock is at the server level. When the phone tries to activate, Apple looks to see if the code embedded in the CPU/BB/NAND/EEPROM is in a locked state.
If you transfer over those IC's and they were previously locked, it won't help at all. You need to transfer over unlocked IC's, hence my answer stating that this is a lot of work, possibly for nothing.
As for programming, you can't program the CPU so you need a matched set to start with.
@refectio I dont know. Last time I went to China, they said it didn't matter if both sets were locked or not. They explained when you swap, the server no longer recognizes it.
댓글 달기
답변을 추가하세요
Kramer 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 27
전체 시간: 1,039
