Ac/heat window unit not heating
I have a whirlpool ac and heat unit that just quit heating all of the sudden. All other functions work properly. What could have happened or could be wrong? Model # ACE184XK0
좋은 질문입니까?
좋은 질문입니까?
@cdunigan this could be a bad thermostat, failed heating strip as well as multiple other issues. You would have to at least remove the cover and post some images of your unit that let's us see what you see. Use this guide 기존 질문에 이미지 추가하기 for that.
이 답변이 도움이 되었나요?
Check so theres still gas inside it, I dont know how you check it on this model.
Usually theres a sensor in one of the pipes that feel the presure of the gas, if you put those two contacts against each other it should start cooling. But dont do it for a longer time, theres often a kind of "oil" in too and if its to little gas/oil you will break it if doing it for a longer time.
You can check for leaks also
이 답변이 도움이 되었나요?
지난 24시간: 1
지난 7일: 9
지난 30일: 37
전체 시간: 5,983
댓글 4개
Hi @jeffreywalton
What is the make and model number of the A/C unit?
jayeff 의
Hi @drmcleanann
What is the make and model number of your A/C unit?
jayeff 의
I am unable to locate the model number. And, it’s the heater that will not function. The fan blows…but, no heat.
John Wilson 의
Hi @squareformat
Without a make and model number it will be difficult to give answers relevant to what the problem may be.
Usually there is an information label attached to an appliance somewhere, perhaps even on the inside so you may to remove the covers etc. unless it has faded and has become illegible
jayeff 의
