주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
VLT 1000 데스크 팬은 지름 30 cm인 4개의 날개를 갖추고 있습니다. 스테인리스 스틸 소재로 제작되었으며 3단계 속도 조절이 가능합니다.
Delonghi Desk Fan - tear down assistance
I have one of these that is about ten years old and there has been a build up of friction from dust or perhaps a lack of lube. Was breaking this down for a clean and lube / oil but cant seem to figure out how to remove the swing control knob. It is the last piece to the puzzle for removing the motor and bearing housing. I have tried to unscrew it both anti-clockwise and clockwise (which only seems to unlock / lock it to the swing motor shaft. as you would expect), but it seems to be held in by something else. There are no screws or bolts visible and I have had a feel around for a circlip but doesn't seem to be one (and no room for one really). Has anyone got experience with these fans and have an idea how to remove? thanks
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
You just need to pull hard to dislodge it.
Update (02/02/2018)
Only the circular spring is holding it in place.
Here is how the knob and oscillating assembly look like inside.
이미지
이 답변이 도움이 되었나요?
점수 4
댓글 1개:
Perfect, thanks!
의 공유
댓글 달기
답변을 추가하세요
Mr Fix 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 16
전체 시간: 1,784
