주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2000년에 출시된 Nokia 3310은 놀라운 내구성으로 잘 알려져 있습니다.
Why do I have no network coverage?
I'm pretty sure the phone is properly unlocked and i put my sim card in and activated it on my cell phone plan and no matter where I go (places where on other phones i get great coverage) i get no signal. Is this an issue with the phone, the carrier, unlocking, or just a bad antenna? what do i do to fix the problem? would i just be better off buying another one since i may have a faulty handset?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 3개
Hi @ncook ,
Do you mean the Nokia 3310 (2017) model or the original 3310?
Have you selected the correct SIM slot for making connections?
의
i am talking about the original nokia 3310 that came out in 2000
의
@ncook
im not sure this'll be correct but the carrier you are on may or may have not switched off 2G services so that may be it.
의
댓글 달기
답변 2개
가장 유용한 답변
The 2000 Nokia 3310 only has support for 2G bands GSM 900/1800MHz. There is no 3G support.
AT&T has shut down all 2G towers.
Make sure your carrier supports 2G 900/1800 GSM.
The phone will definitely not work on Verizon and Sprint.
이 답변이 도움이 되었나요?
점수 6
댓글 6개:
I am on MetroPCS which I believe is owned by T-Mobile and I thought i heard somewhere that MetroPCS uses their cell towers.
의
@ncook MetroPCS is own and operated by T-Mobile. Correct. They only support the 1900mhz frequency. So your phone does not support T-Mobile.
https://en.wikipedia.org/wiki/T-Mobile_U...
If you really like the Nokia 3310, they are making it again. The new one supports T-Mobile/MetroPCS and has a built in FM Radio. The screen is also in color :-)
https://www.ebay.com/itm/263511642450
의
ok thank you
just out of curiosity is there any carrier that still does support the OG 3310?
의
Yes. https://en.wikipedia.org/wiki/GSM_freque...
Note that due to basic physics, lower frequencies (850mhz/900mhz) travel farther, so those are the frequencies that are used most.
의
well if the OG 3310 has a 900mhz band and 900mhz is used the most why doesn't it work
의
댓글 1개 더보기
댓글 달기
Because the Nokia 3310 runs on 3G service and they took down those towers a long time ago
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Really not true. The 3310 3G remaster did, but this version runs on 2G TDMA, which is still available although not to new subscribers, sadly.
의
댓글 달기
답변을 추가하세요
Noah Cook 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 34
전체 시간: 11,342
