주요 콘텐츠로 건너뛰기
Nissan introduced the sixth generation Sentra at the 2006 North American International Auto Show in January.
11 질문 전체 보기
Stalling after tune up and changing mass air flow sensor
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개:
Did you replace the MAF with a Nissan part, or an aftermarket one?
댓글 달기
답변 1개
Did you scan your car prior to installing the MAF to make sure that was the actual problem? Or is it was a mechanic did you see the print out? Then after installing the part, did you clear the codes, test drive and check to see if new or same codes came back?
MAF sensors are very fragile, and can be easily damaged during install by being rougher than necessary.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Marcus Napoleoni 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 445
