주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Motorola Moto E4 Plus(XT1774, XT1775, XT1776 또는 Moto E 4세대)는 대형 5.5인치 HD 디스플레이와 매끄러운 메탈 디자인을 갖추고 있습니다. 5000mAh 배터리, 발수 코팅 및 지문 인식기가 탑재되어 있습니다.
cell got wet screen dead
Motorola e4 plus got wet, I was using for around an hour with not problem at all, now screen is dead still ringing but I cant see anything on the screen
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
marquez3655  just like any other device that does not get cleaned properly. It will fail and shortcicuit. In your case you want to go ahead and disassemble it. Should be pretty much the same way as on here Once disassemble you need to clean it. Use this guide iPhone 액체 침수 손상 수리 to clean it. It was written for an iPhone but the steps are identical for cleaning every device. Once properly cleaned you want to reassemble your phone and change the battery. Always use a new battery with water damaged devices. Then re-evalauate. It is possible that you have an LCD shortcircuit and repalcing that may get your phone back to working condition. Water damage is the hardest to repair since virtually any part may have failed.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
marquez3655 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 3
전체 시간: 409
