주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Eighth generation of the Honda Civic.
headlight its no power
Hi my honda civi 2006 headlight its no power hiw to check the problems
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개
What if they good and still not working?
@germanmanuel
What is the year of the vehicle?
Which headlight is not working, left or right or both?
Do the tail lights/parking lights work OK?
A bit more detail about what the problem is will help
댓글 달기
답변 1개
가장 유용한 답변
Hi @sherwinlaja ,
Which headlight, left, right or both?
If one headlight:
left headlight - check fuses #13 (high beam) & #17 (low beam) in interior fuse box.
right headlight - check fuses #12 (high beam) & #16 (low beam) in interior fuse box.
If the fuses check out OK use a Voltmeter to see if there is power getting to the headlight in case it is a faulty headlight connector or bulb etc.
If both headlights:
check fuse #4 in engine bay fuse box. If this fuse is blown, it should also affect the power windows as well.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Sherwin 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 19
지난 30일: 63
전체 시간: 4,394
