phone has a problem charging
i've assesed a clients phone and the charging jack is okay, but the phone still has a problem charging..where should i look?
좋은 질문입니까?
기기에 대한 안내서, 부품 및 답변에 신속히 접근할 수 있습니다
좋은 질문입니까?
You should check the connections from the Socket Charging to the C - Power Bauur inside the device and your money using a device called Avoometer
이 답변이 도움이 되었나요?
You can replace the charging socket witch is probably damaged unfortunately ifixit doesn’t have a guyed for it so look on YouTube for a guyed and i would say to go to eBay for the part
이 답변이 도움이 되었나요?
To take a look on battery terminal if a well connected second to check life of battery
이 답변이 도움이 되었나요?
Take a carefully look at the battery terminals if we'll connected, you can as well try boosting the battery if situation persist try replacing the battery.
More technical you can run a jumper from the positive terminal of the charging legs to the vbat.
Phone is not power on and showing logo
이 답변이 도움이 되었나요?
@yashdahiya your phone is a Tecno Y3s? What have you checked? Anything happened to the phone? Did it get dropped or any water damage?
지난 24시간: 0
지난 7일: 3
지난 30일: 6
전체 시간: 3,081
댓글 1개
i've assesed a clients phone and the charging jack is not okay, but the phone still has a problem charging..where should i look?
gharib mahmoud 의
