주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
발신자 표시 기능을 갖춘 Uniden D1760-2 DECT 6.0 무선 가정용 전화기.
Flashing light on handset
The red light on all handsets is flashing and there is a rapid beep as dial tone. Can still ring out and receive calls . We dont have telstra message bank activated
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 2개
where is the find button
의 공유
@rhondapollard
Please confirm the model number of your phone?
의 공유
댓글 달기
답변 3개
선택된 해법
Hi @tina51 ,
What is the model number of your phone?
If it is a Uniden Dect 1760 to turn off the light:
With the phone in standby, open the menu and select Global Setup; select VMWI Reset, then select Yes.
Is the phone connected as a VOIP phone service on the NBN?
If it is then are you sure that Messagebank hasn’t been turned On? By default Telstra turns on Messagebank when on the NBN.
What do you get when you dial 101?
이 답변이 도움이 되었나요?
점수 1
댓글 3개:
Thanks so much. Going to global set up fixed it . Yay. Thanks for thatt
의 공유
dect 6,0 uniden
의 공유
@barbaraejones
Unfortunately that's not the model number. It's the signalling protocol used by the phone.
The model number can be found on the bottom of the base station or sometimes under the battery in the phone
의 공유
댓글 달기
가장 유용한 답변
Press and hold the FIND button about five to ten seconds until the beeping stops.
You can also try clearing all incoming calls.
이 답변이 도움이 되었나요?
점수 3
댓글 1개:
there is no FIND button on the menu?????
의 공유
댓글 달기
How do I delete messages...and stop the explitive phone from continuously from flashing?????
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Bettina Slocombe 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 13
지난 30일: 88
전체 시간: 27,676
