주요 콘텐츠로 건너뛰기
Repair guides and support for the Acer line of netbooks including the Aspire One series.
Acer Aspire One zg8 A0531h-1077 Wont turn on
Hello I have A0531h-1077 that doesn't power on, no LEDs come on (charging, HDD, USB, etc.). I've tried a different working charger but no luck. the problem occurred after my son plugged in the wrong charger with different AMP and voltage. Any ideas? Thanks for your help.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 -1
댓글 1개
My bad, its Acer Aspire One zg8 A0531h-1077
댓글 달기
답변 1개
선택된 해법
First i would make sure that you have power coming from the AC adapter. Pull your battery and all your memory and remove all device that are plugged in i.e printer,cam etc. as well as Your AC adapter,. Give it some time and then re-seat your battery. This should reset your Bios. The try to restart with a AC adapter to see, or better to hear, if you get any error code beeping. If you still get nothing, it is time to disassemble your Acer and see what damage you have on the power side of your motherboard. Take a look at the Aspire One Service manual and hopefully you get it going again. Good Luck
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
I will try that tonight and go from there. Thanks a lot for your help.
You are welcome and let us know how it is going. When you check it pay good attention to the caps and resistors on the motherboard. They do have a tendency of giving out under extra amperage. Good Luck
댓글 달기
답변을 추가하세요
Mike 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 4,789
