주요 콘텐츠로 건너뛰기
6s와 유사한 하드웨어 사양의 4-inch iPhone은 2016년 3월에 출시되었습니다. 16/64GB 저장 옵션 및 은색, 스페이스 그레이, 금색 또는 로즈 골드로 제공됩니다. 모델 A1662 및 A1723.
1049 질문 전체 보기
Issue about dry out a iPhone SE that went through the washing machine.
Hi There.
Mu iphone SE went through the washing machine and stayed in there overnight. How can I best try to dry it out? Should I take off the cover and put it in rice or what? I just need to save the contacts and pictures. I have not turned it on yet, I understand that will fry it.
Any suggestion would be appreciated.
Thanks in advance.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Hi @roroeow7
As you know water and electronics and electricity are not a good mix.
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components.
Rice is good to eat but does not fix the problems caused by corrosion.
Don't Put Your Device in Rice. Here's Why...
First do not turn on your phone and then you need to remove the battery as soon as possible from the phone to minimize further damage.
Then you need to completely dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 90%+ (available at electronics parts stores) to remove all traces of corrosion and water. Do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain scents and is not as effective. If you do check the label to verify the amount of IPA
Here is a link to the ifixit guide(s) for repairing your phone.
iPhone SE (1st Generation)
Here are a couple of links that describes the process.
Electronics Water Damage
Repairing iPhone Liquid Damage
You may have to replace the battery as it is very hard to recover a battery from prolonged water damage.
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the boards.
Hopefully after you have done all this the phone might possibly work correctly again.
If this process seems too daunting, take your phone to a reputable, professional phone repair service, experienced in water damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
해당 답변은 도움이 되었습니까?
점수 4
댓글 달기
귀하의 답변을 추가하세요
roroeow7 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 91
