주요 콘텐츠로 건너뛰기
This guide page will help you diagnose problems with the Toshiba Satellite C55-B5200.
9 질문 전체 보기
Where is the motherboard battery?
BIOS time and date is resetting if I don't have the laptop battery in and if I don't have the laptop plugged in. In order to stop that I'll trying to change the motherboard battery. However I do not see it when I take the bottom cover off. I'll trying to find its location.
Manufacturer: Toshiba
Model: C55-B5299
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 4개
선택된 해법
This laptop model does not have a CMOS battery. On the motherboard you will see a spot that one should be located. If you disconnect or let your main battery run dead you will have to re-enter your date and time settings when booting your laptop for the first time.
이 답변이 도움이 되었나요?
점수 4
댓글 5개:
@itsd_btech What is the solution to this problem then? My battery doesn't charge and my laptop only runs while plugged in, and needs bios time update each time I plug into a new socket.
I would recommend replacing the battery with an OEM quality battery. Either your battery is not recognized by the laptop or is failing and needs replaced.
buy a good replacement battery (about $20 USD, put in new battery and charge fully in the off position. Re-enter current date n time in BIOS and all should be well
Be sure to train the new battery! When they first charge they may only last 30 min to 1 hr. But after draining to about 10% or so and fully charging to 100% you will get way longer life. I train new batteries three times for best results, although the most benefit occurs after the first full cycle.
i replaced the main battery, it has no rtc battery, pressed the on button, the on button stays lit for 5 seconds then turns off, the dammned thing wont turn on !!!
댓글 달기
Hi Alx,
I would guess that it may be under this cover.
이 답변이 도움이 되었나요?
점수 3
댓글 8개:
@arthurshi - Authur, You must be good with Finding Waldo puzzles ;-}
It was one of my favorite childhood pastimes :)
This model does not have a CMOS battery on the motherboard. The spot you are showing in the picture looks like a potential placement. If you take the motherboard out you will see underneath there is no battery.
I'm having the same issue. I let my battery die by watching a movie that I fell asleep to. Now all I get is the Toshiba splash screen. No bios, nothing. There is no battery. I looked.
Does anyone know a fix for this?
댓글 3개 더보기
댓글 달기
This model do not have any CMOS battery, …ignore the shape of battery on the mobo, there is no battery on the underside. First time I ever encountered this in my 17 years dealing with computers. It's very unusual but it's true
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
I have a Toshiba Satellite L55-B5267. I am also unable to locate a battery on the board. I am getting prompted for a BIOS password. How do I clear the password. No battery so I am unable to locate the correct jumper location on the board.
Mine did this I replaced the hard drive and reinstalled windows and boom fixed
댓글 달기
I had the same problem. Just replace the battery, fully charge the new battery, set your date n time and you are all good to go.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Alx V 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 22
지난 30일: 128
전체 시간: 15,152
