주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
M331 Silent Plus는 2016년 11월 Logitech에서 출시한 무선 마우스입니다. 이 마우스는 USB 수신기를 통해 연결되며 AA 배터리 한 개로 작동합니다.
How do you open the mouse
Like the questions says.. My scroll wheel has come loose
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 6
댓글 달기
답변 2개
선택된 해법
Try following this guide to open up your mouse.
이 답변이 도움이 되었나요?
점수 19
댓글 5개:
Tks! M280 is same model.
Thanks.. a very useful guide..
Thanks for the guide, been looking for some time, and finally found it. Will try out the steps over the weekend.
Is it possible to remove the scrolling wheel spring? It's so noisy and beat the "silent plus" branding. I did this to all my previous logitech mice but seeing the photos above, it seems that there's no "metal" spring but a black plastic spring instead. Can you confirm? Thanks!
Thanks man
my left click now worked again, just clean it use contact cleaner.
댓글 달기
in the answer provided by @arthurshi , I want to add three points:
In the picture, 4 notches were already highlighted with blue circles, but these 4 do not get locked. There are 3 more notches, in green, which gets locked when mouse is closed.
이미지
1) There is a hole provided to insert a pin/screw driver, in green down arrow, & gently press the lever to the left, 1st yellow direction.
With this the lower portion of mouse will get detached.
2) then, we have to genlty slide the lower case to forward, 2nd yellow direction. For some reason this direction was wrongly mentioned in original answer.
3) Reverse process should be followed to lock the top two notches while assembling the mouse.
이 답변이 도움이 되었나요?
점수 2
댓글 2개:
Thanks for the guide bro, been looking for some time, and finally found it..
ecd, thanks for the addendum instructions
댓글 달기
답변을 추가하세요
bwinter 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 32
전체 시간: 9,173
