주요 콘텐츠로 건너뛰기
모델 A1013, A1052, A1085, 또는 A1107 / 1440x900 스크린 해상도
20 질문 전체 보기
Showing adapter plugged in, but not charging?
When I received my hand-me-down PowerBook G4 I knew the battery was shot, so I just ran it off the cord. It took me a year or two to get a replacement battery but by that time the adapter seemed to be malfunctioning because of the continuous usage.
But after having replaced both battery and adapter just last summer, my PowerBook is having problems again. Now the computer doesn't always recognize that the adapter is plugged in and I have to twist and turn it for it to pop up as plugged in. However, even then it sometimes doesn't charge unless I hold the adapter in place a certain way and of course it's NEVER in the same place at the same time.
Any ideas on what the problem might be and how to fix it?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 -1
댓글 달기
답변 1개
선택된 해법
Assuming your adapter plug is tight you probably need to replace your dc in board. Link to the guide provided. If you can borrow a power adapter and try it first. Good luck.
PowerBook G4 Aluminum 17" 1-1.67 GHz DC-In Board Replacement
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
Kati Krieger 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 592
