주요 콘텐츠로 건너뛰기
2세대 Samsung Gear, Samsung의 Tizen 스마트워치 OS를 실행하는 둥근 스마트워치 입니다. Gear S2는 2015년 10월에 출시되었습니다.
The back cover keeps coming off
The back of my watch keeps falling off. Looks like it was held together with some sort of adhesive.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 9개
FWIW, the battery tutorial linked below doesn't mention any adhesive
Samsung Gear S2 Battery Replacement
Might want to closely examine the unit for broken locking tabs, maybe.
So the part I'm talking about is the part that is directly against the wrist, not after you open it to get to the battery. So if it falls off it exposes the gold part not the battery. It has a small window on it which is usually the sensor
@Jayne a Ahhh OK thanks for the update. Guess the sensor must be part of the charging system then, is that right? Being retired I haven't worn a watch in donkeys years now and so am not really up to date on the newer styled watches. Good luck with your investigations though. :-)
I have tried…seems like it needs some sort of adhesive glue to stay but not sure if I can just use regular gorilla glue
@propman thanks...so frustrating that they want to charge 70 dollars to replace the whole back but all I need is some glue...lol
댓글 4개 더보기
댓글 달기
답변 2개
가장 유용한 답변
It appears to be a compression fitting. See if you can find someone with strong hands and thumbs to press it into place.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
That worked! There was a notch where the dial was that I had to line up and then it took a lot of pressure around the outer edge of the metal back but I heard a few clicks as I pressed very hard around it.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Jayne a 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 11
전체 시간: 4,458
