주요 콘텐츠로 건너뛰기
Repair guides and support for tablets manufactured by Zeki. Zeki tablets include the name “Zeki” in capital letters in the center of the tablet’s backing.
Why are the lnes in the center of my new able
My tablet has lnes in the middle ts red at times an today it's white have seen v3 lines at times new tablet only a few weeks have seen up to 3 different color of lnes don't have anyideal what to try
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
Jerry Hardee  could be an issue with the LCD TAB connection. Post an image of what those lines look like 기존 질문에 이미지 추가하기 If it is the TAB’s then it is not a DIY repair but needs a replacment LCD
이 답변이 도움이 되었나요?
점수 1
댓글 3개:
bruh I already basically said that why do you need to repeat it?
bruh? LMBO! I repeat it because your answer is very convoluted and not very clear. Yes, you added the TAB after but seem to forget that things like "pixels to the motherboard" is really very nondescript. The lines maybe a pixel wide but no pixel will ever connect to anything. A pixel is nothing but the smallest unit of a digital image that can be displayed.
Still have lines will try to find some way to return it hopefully they will repair or replace it
댓글 달기
this problem is caused by loose cables and no connetion in the pixels to the motherboard aka TAB
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
it can be fixed because if you push on the spot on the edge it goes away how take it apart and push on all edges of screen
댓글 달기
답변을 추가하세요
Jerry Hardee 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 8
전체 시간: 142
