주요 콘텐츠로 건너뛰기
2012년 9월 12일에 발표된 여섯 번째 Apple iPhone입니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 검정색 또는 흰색으로 제공하였습니다.
2522 질문 전체 보기
Strange things happening with Apple devices
Just making one post about several Apple products.
My sister is having the following problems with her apple products and brought them to me to work on.
iPhone 5 had a cracked screen, I replaced the screen and the battery. Everything worked fine for about 2-3 days. Now it will not turn on. The battery was still charged to about 50% when it was turned off. Tried to plug it in to charge it and still nothing.I have cleaned the charging port but did not help.
Ipad Air Wi-Fi her husband kept it plugged in all the time. He had no issues with it until the other day when he went to turn it on. Now it will not turn on. Could this have caused the battery to go bad?
She had an iPhone 6 that I changed the screen battery and charging port. It worked for about a week. Then it would not turn on or anything. I tested the tristar chip and found out it was bad.
She used different chargers all original chargers for both devices and has even tried other chargers Apple and non Apple chargers. She has also tried to connect it to a computer to see if the computer would pick it up but still nothing happens.
It just seems strange that it is all happening to her devices, yet I have never had any other customer have issues like this before. Also the iPad Air, has never been taken apart for any repairs, thats what I cant figure out. If anyone has any ideas on what could be going on here please help, as I cant figure this one out.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 3개
HI @b23norris ,
What is your sister's household power supply like?
Have there been problems like surges, outages or even if the supply voltage too high i.e. outside prescribed range?
Has she had problems with any other electrical devices?
Are their Apple devices charged via adapters connected to the power via a powerboard which may have problems?
It seems like there is a power problem of some kind. Just a thought
@jayeff There has not been any power issues in her house. The house is was just built about 5 years ago and her husband had them put suppressors, filters and all that good stuff in the eletrical in the house to help keep any power surges or anything like that from happening. There has been no other issues with any other devices, Computers Tvs, ect...
One of the devices were plugged into a surge protector while the other was pluged in to the wall outlet. All devices are using original Apple chargers.
I still suspect helium. The house probably sits on a natural deposit somehow, or they bought some helium for balloons, medical equipment or something like that, and it is leaking.
댓글 달기
답변 3개
가장 유용한 답변
Let me guess, helium.
https://www.vice.com/en_us/article/gye4a...
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
The most problems I ever have is when doing repairs for family and friends (usually for free). I just try not to do to many of them. Most of the time they don’t even pay for the parts.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
I never do a repair for friends or family for free. They do at least pay for the parts, and I round it up to the next $10 mark. I may not make a lot from them but I also most of the time don't have to do this very often.
댓글 달기
If you have a device that fails a tristar tester, then you know this for sure—-this family uses tristar-killing chargers.
Dead tristar is consistent with all of these failures.
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
Tristar-killing chargers, sounds like something we could sell to the First Order
All chargers are the ones that came with the devices.
댓글 달기
귀하의 답변을 추가하세요
Brent Norris 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 87
