2016 pathfinder sv smokes on start up
2016 pathfinder briefly smokes on start up and is consuming oil 76k no warning lights some loose sludge in valve cover on front
좋은 질문입니까?
기기에 대한 안내서, 부품 및 답변에 신속히 접근할 수 있습니다
좋은 질문입니까?
what colour smoke is it? any car on start up will show a little smoke, if its thin white smoke its just condensation and nothing to worry about. if its a thicker blue then it might explain the oil consumption as this could be related to worn piston rings, valve seals, intake manifold gaskets and clogged oil drains. I would start by replacing the valve cover gasket as its a relatively easy job for anyone to do and usually the most common to go first.
이 답변이 도움이 되었나요?
지난 24시간: 0
지난 7일: 0
지난 30일: 6
전체 시간: 895
