주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Lenovo Thinkpad Edge 13 E31(모델 번호 MT: 0221-A13)은 2012년에 출시되었으며 기본 사양으로 Windows 8이 탑재되어 있습니다.
How do I replace the Touchpad Hardware?
Hi !
It looks like a touchpad hardware problem.
Windows 10 Device Manager indicates Error 24 on the touchpad device driver.
Is there a Touchpad Replcement guide ?
How can I verify if it is a simple misconnected cable or the device itself?
Although I cannot relate the touchpad malfunction to a previous lab visit (on another issue) it might be a simple issue of not re-assembling a flat-cable or something.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi,
Here’s a link to the hardware maintenance manual for the laptop.
Scroll to p.77 to view the necessary steps and then the procedure to remove the top case assembly and microphone module The touchpad is part of the top case assembly.
If it is determined that the touchpad is faulty on p.114 there are two part numbers (part #3) for the top case assembly.
You may have to check which part number is relevant to your particular model variant. Hopefully it may be stamped under the top cover somewhere.
Once you have worked out the correct part number, if you search online using the part number only in the search term of your browser, you will get results for suppliers.
I didn’t check if it is possible to just get a replacement touchpad without the top cover assembly or not. You may wish to follow it up.
Hopefully this is of some help
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
ameirson 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 14
전체 시간: 302
