주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2.5 GHz 듀얼 코어 Intel Core i5 프로세서(최대 3.1 GHz Turbo Boost), 3 MB 공유 L3 캐시.
Charge port replacement question
Hi,
My computer has had trouble charging. I replaced the charger (onE of the pins was stuck) but the problem has persisted. I noticed some burn marks on my charge port and and looking to replace it. Which charge port is the correct one? and which repair guide?
my macbook is a A1278 model, serial number is: C1MMHY1KDTY3
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
@tootscoots according to your serial number your MBP is actually a MacBook Pro 13-Inch "Core i5" 2.5 Mid-2012
2.5 GHz Core i5 (I5-3210M)
Intro.June 11, 2012
Disc.October 27, 2016
OrderMD101LL/A*ModelA1278 (EMC 2554*)
FamilyMid-2012
13"IDMacBookPro9,2
info from here which would make it a unibody model. Heerr is the guide for that MacBook Pro 13" 유니바디 Mid 2012 MagSafe DC-In 보드 교체 and the part is available right here MacBook Pro Unibody 13" and 15" MagSafe DC-In Board
Replace a damaged or malfunctioning magnetic DC power connector. 이미지
제품
$9.99
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Charging ports are easy to damage. Constant connecting and removal of the connector cord can be hard on the port and move, bend, or damage internal components. Sometimes a dropped phone can also cause charging issues. If your phone or mobile device has stopped charging correctly krogerfeedback
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
foster anderson 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 10
전체 시간: 392
