주요 콘텐츠로 건너뛰기
Repair and troubleshooting information for the HP Pavilion dv6000, an HP laptop part of the HP Pavilion series. Released in April 2007.
20 질문 전체 보기
Battery is stuck in laptop.
How can I remove the battery to check if it has been recalled.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개
How is the cover stuck? Can you post a picture?
댓글 달기
답변 2개
선택된 해법
To remove the battery move the battery hold latch to the right and tilt the battery out. See attached pic :-) be careful when you pry with anything, so as in not to break the housing etc. To check the eligibility for the battery recall check on this website it will give you the proper procedure and numbers. Good Luck.
이 답변이 도움이 되었나요?
점수 4
댓글 3개:
make sure you unlock the clips first
if they are in right position just turn laptop upside down or help with a knife or something
heyy thnx for the response but it seems like the battery latch is stuck and not moving
i have the same problem on my dv7
댓글 달기
what if the latch is broken
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Donna Durand 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 7
전체 시간: 5,271
