주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Asus Q304UA는 13.3인치 컨버터블 노트북입니다. 2016년에 출시되었습니다. 모델 번호: ASUS Q304UA 2-in-1.
My keyboard backlight controls do not work.
I am trying to turn on the keyboard backlight with fn+f4, or at least trying to get the popup that says brightness down with fn+f3. All of the keys work, just not when used together. I have tried updating to the latest ATK package, uninstalled and reinstalled the keyboard drivers, and I’ve pretty much exhausted my technical knowledge.
Edit: This is after a hard drive replacement with an SSD.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 7개:
Hi,
Have the keyboard backlights ever worked in your laptop?
Just wondering as there is no mention of this feature in the user manual which is from this webpage.
It is also strange that both F3 and F4 rate no mention at all in the manual. They are both missing from the function key list on p.34
This used to be my sister's laptop, I replaced the broken drive today and was trying to get it setup. She doesn't know, but the Best Buy listing says it has a backlit keyboard, and the keys are marked with a backlight up/down icon, the same as my Q504UAK (the same as the Q304UAK, but with a numpad and bigger screen). I believe I remember the backlight working, but I'm not sure. I read the manual and there is no mention which I thought was strange but it wouldn't make sense to have the keys with no function...
Hi @Gabriel Mascarenas
Check for a hcontrol.exe file This controls the hot key functions
usually it is located in C:\Program Files (x86)\ASUS\ATK Package\ATK Hotkey
Run the program and check if the backlights work when operating the keys
If still no good then I'm not so sure about having keys without a function.
They would use a keyboard that they already have in other laptops and not provide the functions to certain keys rather than producing a new keyboard especially for it. The manual seems to indicate that this is the case.
Given what you have tried about the only thing left if it does have backlights is that it is a hardware fault associated with the lights themselves rather than the keys as I think from memory that there are no other indications or screen notifications etc when operating the backlight keys, only that the lights change
I was working on the hardware when I installed a new SSD to replace the faulty hard drive, and this is my first physical home repair. It is possible I messed something up there. As for running hcontrol.exe I've tried that and had no luck. It also doesn't show up in the Windows Mobility Management window either.
@Gabriel Mascarenas
It's probably best that you recheck what you did.
Just verifying that you did disconnect the battery before doing anything else inside the laptop?
댓글 2개 더보기
댓글 달기
답변 3개
To see if it's a physical problem within the keyboard, you may run some tests using the Windows Onscreen Keyboard which you find in the All Programmes menu under Windows Ease of Access.
Otherwise go back inside and check the tiny ribbon cable hasn't become loosened at both on the motherboard and the keyboard ends.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
I tried using the onscreen keyboard to press fn+f4 to brighten the backlight, but that didn't work. Normally when I used to turn the backlight on it'd show a popup that says brightness up under the backlight icon, but not even that shows up, with both the onscreen and physical keyboards.
@Gabriel Mascarenas The Brightness slider appears in action center in Windows 10, version 1903. To find the brightness slider in earlier versions of Windows 10, select Settings Gear-shaped Settings icon > System > Display, and then move the Change brightness slider to adjust the brightness.
If you don't have a desktop PC and the slider doesn't appear or work, try updating the display driver. In the search box on the taskbar, type Device Manager, and then select Device Manager from the list of results. In Device Manager, select Display adapters, then select the display adapter. Press and hold (or right-click) the display adapter name, then select Update driver.
댓글 달기
Hi Gabriel I had exactly the same problem as you after upgrading my ASUS laptop C drive to an SSD.
My backlighting was gone and the hotkeys did nothing.
To fix it on mine I went to C/ProgramFiles (x86)/ASUS/ATK package/ATK hotkey and then clicked on "HControl" and ran program.
Next thing you know everything worked as expected again. Sure hope this works for you cheers Andy
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Ways to Fix Your Backlit Keyboard When It's Not Working on
Check if Your Keyboard Comes With the Backlit Feature.
Increase the Brightness Level.
Update Your Keyboard Drivers.
Run the Keyboard Troubleshooter.
Perform a Clean Boot.
Regards,
Will
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Gabriel Mascarenas 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 6
전체 시간: 3,205
