주요 콘텐츠로 건너뛰기
The Roomba Red 4100 is a vacuum cleaner robot produced by iRobot that can clean a room all on its own.
12 질문 전체 보기
Missing the part above the electric plug-in
I am missing the "whatever" is right above where the charger plugs into the cleaner. What is that and where/how can I find a replacement? When plugging in the charger, no lights come on and it appears not to be charging. Thanks.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
Sue, any chance you could post an image of the part needed/missing?
댓글 달기
답변 1개
선택된 해법
If I am not mistaken, and without any visuals, my best guess at this time would be that you are talking about the cover for the serial port. It is located directly above the charging socket. this should not have anything to do with your Roomba not charging. If the light on your charger is not coming on at all, try a different wall outlet. Also, use a multimeter and check the output of the charger, it should be 22volts. For the Generation 1 and 1A : If the power light is off or flashing, discard both the Home Base and the Power Supply and replace the main pcb on the Roomba. This is the suggestion of the service manual, because a flashing light power supply can destroy the PCB. If your power supply is working properly, start by taking a closer look at the battery. Batteries do degrade with time, and it might be possible that you need new one. Hope this helps to get you stated. Let us know how it is going. Good Luck
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
Sue 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 1,001
