주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
USB(Universal Serial Bus) 케이블은 컴퓨터, 스마트폰, 프린터, 카메라 및 기타 전자 기기와 같은 장치를 연결하는 데 사용되는 일반적인 유형의 케이블입니다. 장치 간의 데이터 및 전원 전송을 위해 설계되었으며, 장치 충전에도 자주 사용됩니다.
USB headsets not recognized by Windows 10
I just built a PC using a ASUS B550 F-Gaming from Asus. I installed all the drivers updated everything and all works great. Except USB headsets. They work when I use the 3.5mm jack but nothing happens when I plug them in using USB. I tried connecting to different USB ports (2.0 and 3.0) and I tested all USB ports with my external hard drive and testimg them on my laptop, everything works. The LEDs even turn on when I plug them with USB, but Windows doesn't seem to recognize them, it doesnt even list is an unknown device, it's like they aren't even connected at all.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
LED’s turning on just means the ports are getting power.
First of all update your BIOS, if you haven’t done this already.
Make sure the latest drivers are installed from the ASUS web site and don’t forget latest chipset driver from AMD:
https://www.amd.com/en/support/chipsets/...
May be uninstall the USB drivers, run a cleaning utility like Advanced System Care, Ccleaner, etc. reboot and reinstall drivers if Windows doesn’t automatically do so.
How is it now?
I can’t remember off hand where the settings are for the USB ports but just cruise through the BIOS/UEFI advanced screen.
You tested all the USB devices on your laptop, right?
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
Martin Knezovic 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 16
전체 시간: 1,901
