주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2012년 6월 출시 / Turbo Boost를 탑재한 Core i7 프로세서 / 최대 1 GB GDDR5 비디오 RAM
Mid 2012 MBP Hardware Upgrades
I want to upgrade my laptop’s current HD & RAM, possibly removing the Optical Drive as well since it doesn’t work anymore.
Any Suggestions ?
It’s not for super critical work such as Audio or Video Editing, I just need it to be faster, or as fast as it can get.
Thanks in advance.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
To start with I would bump the RAM to 16GB which is the systems limit MacBook Pro 15" Unibody Mid 2012 RAM 교체
As for as drives I would go with a 1TB so you have plenty of space. I would go with a SSD Vs HD as its just more rugged and uses less power MacBook Pro 15" Unibody Mid 2012 하드 드라이브 교체.
The one issue you do face is the HD SATA cable will likely need to be replaced if you still have the original HDD in the system as the original cable was not able to run at the higher SATA III (6.0 Gb/s) data rates the SSD will push without encountering issues MacBook Pro 15" Unibody (Mid 2012) Hard Drive Cable I would also apply a strip of electricians tape on the upper case where the cable crosses over and explained here Your Hard Drive Cable Is A Ticking Time Bomb
The last issue is making sure you don’t damage the cable installing it. A common failure I see is people crease the cable which damages the thin foil wires with in the cable. I use an old BIC pen ink straw as a bending brake to form the bends so I don’t exceed the radius of the straw.
I would leave the optical drive alone as it needed for structure and with one large drive you should not need a second.
Replace a damaged cable connecting the hard drive to the logic board in your laptop. 이미지
제품
$19.99
MacBook Pro 15" Unibody Mid 2012 하드 드라이브 이미지
안내서
난이도:
조정
20 - 30 minutes
MacBook Pro 15" Unibody Mid 2012 RAM 이미지
안내서
난이도:
쉬움
10 - 45 minutes
이 답변이 도움이 되었나요?
점수 3
댓글 3개:
I think the original HD was already replaced because the HD in it now is a 1TB, but good looking out with regards to the HD Cable installation.
의
An SSD will give you a perceived 100% speed increase.
의
That trick with the old bic ink straw to limit the radius of a bend for the ribbon cable - I'll be keeping that in mind.
의
댓글 달기
답변을 추가하세요
immanueltnt 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 27
전체 시간: 249
