주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
ATX 미들 타워는 다른 중형 컴퓨터 타워와 동일한 일반적인 구조와 부품을 가지고 있습니다.
New build, No post
Question
Just started a build this morning, getting power to board, fans are spinning but it won't post at all, I've taken it apart multiple times and completely reassembled. I'm running on an Asrock b450m motherboard.
Have rinserterd ram multiple times and cleaned it as well.
Any help is much appreciated.
Thanks in advance
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
Hi,
Have you connected a system speaker to the appropriate motherboard header pins to hear if there is a beep error code when starting?
See this answer as it has links for a Asrock B450 Pro 4 manual which should be nearly the same at least for system speaker connection and error codes. Assistance with diagnosing my mystery fault
의
댓글 달기
답변 2개
선택된 해법
Fixed, old cpu was a ryzen 5 apu with integrated graphics. New one did not have integrated graphics *facepalm* installed gpu and everything is posting and working fine.
Thank you for any and all help.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
We all have duh! moments. But it is working now. Good one!
의
댓글 달기
가장 유용한 답변
You didn't give us very many details.
For starters:
  • What CPU do you have and is it on the ASRock CPU support list for your motherboard?
  • What version is the BIOS?
  • Is the RAM ion the ASRock support list?
Look on the ASRock website's support for your motherboard.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
Cole Walker 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 15
전체 시간: 473
