주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
15.6인치, Intel HD 그래픽, Core i3 2330M, Windows 7 Home Premium 64비트, 4GB RAM, 500GB HDD
I have a problem with the processor fan working
When I turn on the device, I hear a violent sound of the fan that lasts for 4 seconds, with the device vibrating violently And also when I play or do a task on the device, knowing that I have cleaned the dirt.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Hi,
Here’s the service manual for the laptop.
Go to p.75 to view the necessary pre-requisite steps and then the procedure to remove the thermal cooling assembly. This will give you access to the fan so that you can check if it is OK (clogged with dust?) or if it is faulty and needs to be replaced.
If it is faulty then replacement fans are available online. Just search for Dell Inspiron N5110 fan or use the information from the label on the fan itself, to find suppliers that suit you.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Forg Eex 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 20
전체 시간: 225
