주요 콘텐츠로 건너뛰기
The Razer Blade (2018) is a 15.6-inch gaming laptop released in May 2018.
20 질문 전체 보기
Razer Blade 15 Advanced Screen Replacement
I have the Razer Blade 15 Advance with an RTX 2060. Last night my son threw a car at it an broke the screen. I see some replacement screens on amazon but they say that they are for the GTX 1060/1070 models. Will this screen work for my RTX 2060 model?
https://www.amazon.com/EM-EMAJOR-TECH-LL...
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 2개
Can you take out the screen and post a picture of the back here? To do this, go to Options>Edit on your question. Put your cursor after the last piece of text and hit enter/return on your keyboard. Select the image icon, then select Upload. After your image is finished uploading, select it. Finally, select "Submit Revision"
Sure I'll take it apart this weekend and send some pics.
댓글 달기
답변 1개
선택된 해법
I’m almost certain it will work with your current model(same screen size, same amount of pins on the connector). If you want to be sure you got the right one, I found a screen with the same model number here.
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
I ordered this screen like 1 hour ago after I took it apart. I really appreciate the help and confirmation on my order.
댓글 달기
답변을 추가하세요
Anthony Johnson 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 10
전체 시간: 745
