주요 콘텐츠로 건너뛰기
PC에 사용되는 일반적인 그리고 일반적이지 않은 케이블
20 질문 전체 보기
HDMI Cable End Needs Replacement
I have a damaged HDMI cable end that needs to be replaced/ repaired. The cable is behind walls and is a very long run 100ft +/- I’m trying to find out if the damaged end can be replaced.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
가장 유용한 답변
Hi @elmo1234 ,
Hopefully there is enough slack in the cable to allow for a new connector to be wired in.
Here’s a video that shows how to wire a HDMI connector that may help.
It also may depend on what type of HDMI connector is being used.
Connectors are also available from here and here (supplier examples only)
if doing this yourself seems too daunting contact a reputable, professional electrician who also does data, TV wiring, security installations etc and ask for a quote
이 답변이 도움이 되었나요?
점수 2
댓글 달기
해당 답변은 원래 다른 질문에 답변 된 것입니다.
Hi @elmo1234
Referrals are too subjective and are usually not acceptable on ifixit as it is mainly a DIY forum where people can offer advice on what you can do to fix the problem yourself.
Here’s a link to some services in your area who may be able to help you.
Check their reviews and then go with the one you prefer.
Moderator.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Wayne 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 36
지난 30일: 98
전체 시간: 4,912
