black screen stuck in bios mode
cursor keeps blinking upper left hand corner of screen
좋은 질문입니까?
기기에 대한 안내서, 부품 및 답변에 신속히 접근할 수 있습니다
좋은 질문입니까?
Your computer is not finding the boot drive. Take a look in the BIOS.
Press F10 when the HP Logo screen appears to get into the BIOS menu.
See what hard drive is listed. Select it as your boot device. If one is there and it still does load Windows then either the drive itself is damaged or more likely Windows is corrupted. Does the Windows loading screen come up at all, even for a short time? If it does shut down 2 or 3 time when that screen appears with the power button. Windows 10 will open into the Advanced Start-up environment
While in the Advanced start-up environment, use the following steps to use Start-up Repair:
If the above doesn’t help do the same as above but this time select “System Restore” from the “Advanced Options?”
이 답변이 도움이 되었나요?
지난 24시간: 0
지난 7일: 0
지난 30일: 8
전체 시간: 1,060
댓글 2개
What Operating System do you use with this computer? Have you tried pressing the BIOS menu key?
Andrew S 의
Cort Christiansen BIOS mode or BIOS screen. Not sure about the BIOS mode but it should not be a black screen. This sounds like your computer is not finding it's operating system.
oldturkey03 의
