Won’t turn on
Put in a gpu and power supply and my pc wont turn on
좋은 질문입니까?
기기에 대한 안내서, 부품 및 답변에 신속히 접근할 수 있습니다
did you reseat the main connector to the board? check the power switch on the header and make sure its still plugged in.... try jumping the power pins? reseat the power connector on the GPU? is this a modular or semi modular power supply? is the GPU seated all the way into the connection on the board? is the power supply rated for the GPU and all other components for your computer.... 100's of what ifs....
이 답변이 도움이 되었나요?
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 83
Hi,
What is the make and model number of the motherboard?
Was it working OK before you plugged in the GPU card and PSU or is it a new setup?
if new what is the make and model number of the GPU card and the PSU?
jayeff 의
Is it newly build or was wroking well before after changing gpu and now this problem came up?
Tech Jass 의
@jashan0 it was working well before a I added my new gpu and psu
Keegan Isma 의
@Keegan Isma
What happens if you remove the GPU card and the PSU and restore it to what it was before, does it work OK again then?
Providing the motherboard, gpu card and PSU make and model information will help us to help you.
jayeff 의
Return the computer to it's original working condition, Then replace 1 unit at a time and test it each time to isolate the faulty part. Please contact us again if you need more ideas /help with this issue!
Richard Lilja 의
