주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Asus Zen AiO Pro Z240IC는 4K 초고해상도 화면과 1TB 하드 드라이브로 잘 알려진 일체형 데스크톱 컴퓨터입니다.
ASUS All-in-One Zen Reassembly Help
@jayeff Fix It, friends,
I have a 2018 Asus All in One "Zen" that I tore apart to replace the two hard drives and to upgrade the RAM. Unfortunately, two wires disconnected from the motherboard when I flipped the board over to replace the M.2 HD/card. I can't seem to find where they go on the board - frustrating.
Pictures: These two wires, one black and the other white; both of these wires lead to the top of the left screen (see pictures).
  1. I would like to know where these two wire leads go to, an antenna?
  2. Each end of the wires is not soldered, and the tips have a very small round connector. Once these two wires find their home on the board and would like to finish this project.
Who can assist me with this - please?
이미지
이미지
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
선택된 해법
@sdotraffic those are the wires for your WLAN adapter. They are antenna wires. Those should connect to the top of your WLAN card. Something like this
이미지
Give us the complete model number for your computer so we can verify this.
이 답변이 도움이 되었나요?
점수 1
댓글 7개:
@oldturkey03 turkey03 - good catch! I just returned home from work.
Here's the Asus model # Zen AiO 24 ZN242 Special Edition
I appreciate your assistance.
의
@sdotraffic just checked some of the few images about this model that I have available at it is the same setup as shown on this guide Asus Zen AiO Pro Z240IC Take a look at your WLAN card and you should see the two connectors.
의
Very helpful, I see where the two wires are to be plugged in. I assume then that the tape on the wires are to be over each connection point, correct? It's a project for the weekend. Thank you for your assistance @oldturkey03
의
@sdotraffic that sounds correct and the tape may even offer some EMI protection.
의
I've been out of commission for the past two weeks with the dreaded Covids, thanks for the help, everything went back together, and I only have one extra screw left!
의
댓글 2개 더보기
댓글 달기
답변을 추가하세요
John S 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 25
전체 시간: 810
