주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
이 페이지에서는 Dell Vostro 5480 수리를 위한 부품 교체, 매뉴얼, 문제해결 안내서를 다룹니다. 집에서 Dell 5480을 수리하는 데 필요한 문제해결 및 수리 안내서를 확인해 보세요.
Steps of replacing a Swollen Battery
I have detached the swollen battery but my question do I just put on the new battery or what should I do because I am afraid of the new battery being swollen as well. So my final question is, could there be a way to check why the battery is swollen so I can keep in mind when I am using or is there something wrong inside the motherboard?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개
Please tell me that you have taken out the swollen battery.
의
댓글 달기
답변 1개
선택된 해법
iFixit has a very good guide for what to do with stolen batteries, which I will link here. To give the spark notes of the article, battery swelling occurs when the chemical reaction that is used to generate battery power no longer completes perfectly. This causes outgassing, which results in the battery swelling.
You need to turn off the device and do not charge it. You need to carefully remove the swollen battery and dispose of it properly.
To answer your question your new battery should be ok if it has been handled properly and if it is a new battery.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
Jack Jin 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 10
지난 30일: 19
전체 시간: 285
