주요 콘텐츠로 건너뛰기
A Desktop PC built from off-the-shelf DIY parts, rather than a prebuilt from a major manufacturer. These can also be built by an SI using off-the-shelf parts.
20 질문 전체 보기
Retrieving documents from another computer
I have a custom-built gaming desktop computer that beeps continuously when I turn it on so now I have a newer gaming computer but would like to retrieve files from the first computer. How do I do this if the other one doesn't turn on?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Julie Lafountain the easiest would be to remove the storage HDD from computer one and place it in an external USB case. Then you can take it and connect it to computer #2 via USB cable and access the files. We would need to know what HDD is in computer #1 to suggest which external case since it has to match the Hard drive connector. Most likely something like this would work.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Julie Lafountain 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 38
