Laptop not turning ON on Battery Power
Hi,
My Laptop does not turn ON on Battery Power but Turns ON once I connect the Power Adapter, some issue with motherboard,
Battery is Charging and Gives Backup, I have tried below things
1) Replaced Primary Battery
2) Updated BIOS to Latest Version
3) BIOS Reset to Factory settings
What could be the reason, if any part on motherboard needs to be replaced
좋은 질문입니까?
Hello. Just some follow-up to your question.
When the AC power is plugged in and the computer is booted, does the computer display the battery power level as per usual or is it missing? If available, what percentage is displayed?
RogueParticle 의
Hi, Yes it showing the battery bar and percentage properly
Arun Nayak 의
@techfix28
Does it then turn off if you remove the power adapter or does it stay on?
What is the model number of the motherboard (printed on the motherboard itself)? e.g. BUCKS UMA 16872-1 448 0C?????
jayeff 의
It does not turn OFF, if I remove the power adapter and goes on battery power, and gives backup
Bucks_UMA_MB
16872-1
448.0C204.0011
Arun Nayak 의
