주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Fluke 77 Series III 멀티미터는 산업용 품질의 다목적 멀티미터입니다. 이 장치의 부품 교체 난이도는 문제의 종류에 따라 단순한 수준부터 중간 정도로 복잡한 수준까지 다양합니다.
Is my fluke 77 blown?
I tested an electric fence with my Fluke 77 series II. Bad idea. Now I can't read AC/DC voltage or amperage, or resistance. I've replaced the fuse. I'd appreciate any assistance.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 3개
I've inadvertently 'stressed' tested a few multimeters over the years. Replacing blown fuses always corrects my mistakes. Did you check the fuse again? Is the battery good, connected correctly (polarity)?
@tlampros what type of fence and how did you (unsuccessfully) test it?
I've replaced the fuse, so the unit is back on, but it is not reading V,A or ohms.
I connected the positive to the fence and put the negative in the ground. I'm pretty sure it was set on Vdc.
I replaced the battery, but I'm still getting the battery indicator on the screen. I'll try a newer battery.
댓글 달기
답변 1개
가장 유용한 답변
@tlampros I guess the good thing that even for a meter there are manuals :-). Start off with the flowchart as designed by Fluke
이미지
After that, download 77 Series III and see if you can find out what happened to your meter. Looks like U1 could be the issue
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
Tom Lampros 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 8
전체 시간: 545
