주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
모델 A1989, EMC 3358. 기존 디자인을 새롭게 개선한 모델로, 프로세서 옵션이 업데이트되었으며 키보드 소재가 변경되었습니다. 실버 및 스페이스 그레이 색상으로 제공됩니다. 2019년 5월 출시.
Microsoldering components not sticking
이미지
Hi
I have done microsoldering before and had no problems with components not sticking but this time I am having no luck what so ever
Does anyone have a solution for this
It would be greatly appreciated if someone could help me with this one because I have done what I know
Used the correct tip for the job
Used flux
Tinned the pads
Used the correct temperature
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 30개
What component is it you're replacing?
If it's a cap, res or inductor from a roll of components, I suppose it could be something off with the terminals on the component (I rarely have that though). Maybe try another component if you've got one?
의
It’s a verity of components
Caps
Resistor
Ferrites
Iv tried loads off my roll and they are all doing the same thing
의
Huh, that's weird; I've come across the odd comp in a roll here and there, but never several on several rolls...
Did you buy these from the same vendor you've always used? (Reputable, like DigiKey or similar?)
의
This is actually my first time ordering from Digi-Key
Every other time was off a donor board
의
Oh and they were all from Digi-Key
의
댓글 25개 더보기
댓글 달기
답변 3개
선택된 해법
Hi
I found tinning the components would help make things a bit easier
Perhaps they just needed a head start to want to stick ?
Thanks to everyone who has helped me
@oldturkey03
@danj
@arbaman
@imicrosoldering
@flannelist
And lemerise(sorry It wouldn’t let me put a @ for that one)
Thanks again:-)
이 답변이 도움이 되었나요?
점수 1
댓글 달기
가장 유용한 답변
The solution for this is “more heat” One of the first things you need to learn when starting microsoldering is “ground plain” and its effects.  For the component you have showing I would be using an iron to tin the pads so they are puffy and then use hot air to place the component.
이 답변이 도움이 되었나요?
점수 5
댓글 22개:
Same as I do, when it's cold I join forces, heatgun in one hand and iron in the other.
의
Hi Chris
Your advice for more heat is greatly appreciated and I will try it again
I did try 500deg c and even THAT didn’t work Witch really had me thinking, is it just a bad reel of components?,the reason for me thinking this is it’s the second time this has happened ,I started with one bad component and tried to apply my new one and no luck ,so I tried another part of the board and I got no luck ,so I tried a different component all together (a fuse previously it was a cap I was trying so it’s a different reel)and it went on with no problems
I am aware that this sort of thing is uncommon to the point of nearly unheard of but I can get my head round it as I have done microsoldering before on all sorts of devices and never ever had this problem!
I was told by some people here try a lower temp according to what the components listing said so il try that as well
thanks again for all the help it’s means a lot!:-)
의
@hellomacos - More heat is not more temp! Its making sure the board is at a high enough temp so the area you are working on is at temp.
Think of a sheet of copper heating one corner only requires heating the corner area, but the rest of the sheet of copper will wick the heat away quite quickly so you need to hold the heat to the area long enough so the area stays warm (just below the flow temp of solder) so when you focus the heat to do the soldering task the soldering the joint doesn't fail!
We call this pre-heating. Depending on the size and shape of the logic board the area might not need too long to warm or it may need more as there is a lot of copper which is wicking the heat away.
Once the board is at temp using an iron to tin the pad if its bare. Frankly, I just use some solder-wick to flatten the joint to place the small SMD just using flux paste to hold it in place adding fresh solder either using hot air or an iron. Again the component size and what the area has that I need to worry about and the amount of copper which will suck the heat away.
의
@danj
Thanks I will try the temp at 375deg c and a higher more heat and plenary for flux
Thanks again for the advice:-)
의
@hellomacos I don't see a lot of flux residue on your solder pads. Looks like a blob of solder is stuck to the pad. More heat, more flux should help with this. You must tin the solder pads properly, tin your soldering tip.
의
댓글 17개 더보기
댓글 달기
Make sure you thin the two pads with a nice amount of solder then add a small amount of flux. Heat the pads with hot air and when you see the solder liquify just drop the capacitor on the pads using tweezers. On a Qwick hot air station I use 430 with 50-60 air flow for a 0201 component. BTW check the black IC near this location I think there's a bridge on two pins.
이 답변이 도움이 되었나요?
점수 2
댓글 3개:
Thanks for the advice I give it another shot!
I checked for a bridge and there isn’t one
It looks like one in the photo but it’s just the light reflecting of some isopropyl alcohol that hasn’t evaporated yet
Thanks again:-)
의
@hellomacos I'd give attention to @honakrisi, everything else notwithstanding oxidation will keep things from sticking.
의
@uchetil
I l will have a look
Thanks for letting me know:-)
의
댓글 달기
답변을 추가하세요
HelloMacOS 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 22
전체 시간: 1,226
