주요 콘텐츠로 건너뛰기
The Nissan Altima is a mid-size automobile manufactured by Nissan, and is arguably a continuation of the Nissan Bluebird line, which began in 1957.
20 질문 전체 보기
How do I replace the instrument cluster lights.
I have been trying to replace my instrument cluster lights. I have watched many videos and looked all over trying to find out how for my specific vehicle. I can remove the cluster but then the circuit board has one light bulb on it that indicates the head lights. Please help.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개:
Hi,
What is the specific Altima model and year of your vehicle?
Have you checked for small smd LEDs on the board?
댓글 달기
답변 2개
normally the bulbs are very small and they are socketed.
If you have the cluster out, you should be able to drill down, removing the PCBs till you can see and remove/replace the bulbs.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I just ran into this issue as well I tore the entire unit apart on my 2006 nissan altima s with 2.5l to find out the lights are non serviceable led bulbs soldered to the cluster board.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
John Lemon 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 17
전체 시간: 567
