Why is my motherboard beeping but my pc still boots
It does 1 long beep and two short beeps
I can boot to windows but not into bios
Rx 580 xfx 8gb
A320m a pro max
16gb 8x2 ram
1tb hdd
240gb ssd
Ryzen 3 3100
Evga 600w psu
좋은 질문입니까?
기기에 대한 안내서, 부품 및 답변에 신속히 접근할 수 있습니다
Rx 580 xfx 8gb
A320m a pro max
16gb 8x2 ram
1tb hdd
240gb ssd
Ryzen 3 3100
Evga 600w psu
좋은 질문입니까?
Hi,
According to this MSI bios beep-codes link, a 1 long, 2 short beep error code is a Monitor or display card error, (if you have Award BIOS) so it seems strange that you can boot into Windows OK with presumably a display.
Try disabling fast startup in Windows, shut down the PC and then check if you can enter BIOS when starting by pressing the Delete key before it boots into Windows.
Go to Control Panel > Power Options > Choose what the power buttons do > Change settings that are currently unavailable > Uncheck Turn on fast startup (recommended) > Save changes.
You could also try accessing BIOS through Win 10 and see if that works.
이 답변이 도움이 되었나요?
지난 24시간: 0
지난 7일: 0
지난 30일: 7
전체 시간: 1,091
Are you pressing the delete key when you boot up the computer? I found the manual and it says that's the key for BIOS
Pookie 의
