주요 콘텐츠로 건너뛰기
Apple의 올인원 데스크탑 컴퓨터. iMac은 2006년부터 2021년까지 Intel 프로세서를 탑재했습니다.
Building an iMac without a display
I plan to use my 2017 iMac as a display, following the instructions in this YouTube video.
That will leave me with everything besides the monitor outside of the iMac case.
My question is this: has anyone put these components together in an alternate form to get a working iMac without a monitor. Will the iMac logic board even boot up without a LCD panel attached?
Alternately, we could leave all the logic in the iMac case, but then we would need to mount the iMac display panel in an alternate case. Has anyone got an example of this we could use as a guide?
Thanks for any pointers!
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개
What is your goal here? To have a working display to use on a regular Windows PC or to create a headless Mac system reusing the iMac logic board.
Sadly, the iMac is designed in such away that you really can’t use it in a PC case. It’s designed to fin within the iMac case.
Both!
Plan is to use the screen in the original case with another Mac, but I have a good idea how to do that.
Goal is to _also_ re-house the power and logic in something else. I know it won’t fit in a PC case.
The questions are:
(A) will iMac logic board boot w/o a monitor? And
(B) has anyone successfully re-housed iMac hardware in a smaller enclosure of any sort?
댓글 달기
답변 1개
선택된 해법
A - The logic board requires the display to function, the SMC logic needs access to it and the fans Otherwise SMC will assume there is a failure which will push the CPU into Safe Mode with a much lower clocking
B - The logic board is setup to be housed in a vertical configuration.
Over the years people have tried none that I know of who wanted to do the same as it wasn’t worth it.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Eric 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 10
전체 시간: 360
