주요 콘텐츠로 건너뛰기
2012년 6월 출시 / Core i7 프로세서 Turbo Boost 포함 / 최대 1 GB DDR5 비디오 RAM
20 질문 전체 보기
MacBook Fans Max on start up and lags very bad
So my 2012 macbook pro just recently started kicking the fans on high during start up. Right as the progress bar is loading the fans kick on and then everything bogs down really bad. Im able to get logged in and I can open and close applications, but its very slow and lags very bad with the spinning beach ball coming in intermittently. About 15-20 minutes later the fans die down and everything runs as it should. Im currently typing on the unit and the internal temp says 109 farenheit and fans are at 2000 rpm. Not sure if its worth dumping money into this thing or just scrapping it. Any ideas where to start? Was thinking maybe a new battery to begin with and the logic board being a last resort...
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 3개:
Did you try running the onboard diagnostics? Restart you system and then press and hold the D key to enter, depending on your maOS version it might no run Apple messed it up. If that fails install the great app TG Pro you’ll need to get the full version to get the diagnostic services. Let us know what you get for errors.
Thats the hard part, there's no way to replicate it, sometimes it runs perfect, other times it has this problem.
@Luke Lumley - Erratic behavior aims me to either a bad drive cable or the drive is having issues.
What is your drive? HDD or SSD, how big and how much free space does it have.
댓글 달기
답변 1개
Darn it, The GPU Failed!
You will need to replace the logic board.
Part: http://www.powerbookmedic.com/MacBook-Pr...
Guide: MacBook Pro 15" Unibody Mid 2012 Logic Board Replacement
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
I don't think that's the case. Once it comes out of the lag phase it runs like a champ.
댓글 달기
답변을 추가하세요
Luke Lumley 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 66
