주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP Pavilion 17-g192dx는 i5 프로세서를 탑재했으며 가격은 약 300달러에서 400달러 사이입니다. 이 기기에는 Windows 10이 기본으로 설치되어 있습니다.
screen sides are broken do I replace hinges
이미지
이미지
이미지
How can I fix this broken screen siding ? can i replace hinges only
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
선택된 해법
Hi,
Here's a maintenance and service guide, that will help you to replace the hinges. Whilst it is not for your exact model, HP still links to it on the support page for your model.
The specifications for your model show that the LCD is a HD screen. It doesn't specify whether it is a touchscreen or a non touchscreen.
Given this there are two options to choose from in the guide as to how to remove/replace the hinges and what their part number(s) are to find replacements:
  • If the screen is a non touchscreen, go to p.57 to view the procedure to remove the LCD panel. At p.60 the hinges are being removed. The part number for the hinges, left and right (including the screw covers) is 809297-001. Search online using the part number only to find suppliers that suit you best. This part number has been verified as applicable to your model using the HP PartSurfer website.
  • If the screen is a touchscreen, go to p.62 to view the procedure to remove the LCD panel. At p.65, the hinges are being removed. The part number for the hinges, left and right (including the screw covers) is 809299-001. Search online using the part number only to find suppliers that suit you best.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Rajat Bhatt 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 12
지난 30일: 20
전체 시간: 322
